The circle is complete.
Posted: Fri Jan 12, 2024 11:13 am
by JiveTurkey
Re: The circle is complete.
Posted: Fri Jan 12, 2024 11:26 am
by Devin
Bussin ong frfr
Posted: Fri Jan 12, 2024 11:42 am
you know... a FRFR is an amp. It doesn't matter what trendy name they give it, it has a preamp/input section, a power amp and a speaker. Which = amp.
Not saying you JT, but I think it's funny how some people saying they're going ampless but take a FRFR monitor to the gig. That's not ampless. It's just replacing an amp that sounds good for one that sounds like nothing and adding a computer in front of it to get what you could've gotten from a better amp. Makes sense
Posted: Fri Jan 12, 2024 12:00 pm
by JiveTurkey
GuitarBilly wrote:you know... a FRFR is an amp. It doesn't matter what trendy name they give it, it has a preamp/input section, a power amp and a speaker. Which = amp.
Agree 1000%. Add to this (in this case) that the damn thing weighs the same as if you just took your amp and, well; there you go
As I say all this; I would still love to roll up in some store where they had one and bring my modeler of choice and run through one. If only to compare it to the things I have used for a similar purpose. The physics certainly aren't going magically correct themselves vs. just playing through a head and a traditional 4x12 cab
Posted: Fri Jan 12, 2024 12:27 pm
by Marc G
jesus... 95lbs..... I thought the entire point of having a FRFR rig is to keep shit light lol
Posted: Fri Jan 12, 2024 1:29 pm
by JiveTurkey
Marc G wrote:jesus... 95lbs..... I thought the entire point of having a FRFR rig is to keep shit light lol
Yeah not quite hitting that goal with this piece
Posted: Fri Jan 12, 2024 1:40 pm
by Devin
I'm buying two and using them as my PC speakers in my office
I've been trying out the Celestions Neo V Types. They're pretty good speakers. I loaded a 1x12 and a 2x12 with them and it made a huge difference in weight since the speakers are only 4 lbs each. I am going to do a 4x12 later this year.
Nothing to do with FRFR but as far as keeping weight down it's a good option. Especially on a 4x12. V30s weight 10.5lbs each. The Neo V-types weight 4lbs.. So you go from having 42lb in speakers to 16lbs. Good difference there and they sound really good.
Posted: Fri Jan 12, 2024 1:52 pm
by JiveTurkey
Devin wrote:I'm buying two and using them as my PC speakers in my office
GuitarBilly wrote:I've been trying out the Celestions Neo V Types. They're pretty good speakers. I loaded a 1x12 and a 2x12 with them and it made a huge difference in weight since the speakers are only 4 lbs each. I am going to do a 4x12 later this year.
The DV Mark cabs are the lightest cabs I have ever had. I have never seen the 412 but the 212s are like 22lbs or something ridiculous
Of course; the construction and cab mass are going to have an effect on the tone in whatever way. But those specs are impressive no matter how you look at it.
Posted: Fri Jan 12, 2024 2:49 pm
I tried the DV Marks and they were actually what made me stay away from Neo speakers. They sounded very harsh and thin. But that was years ago and maybe they improved them. The Neo Celestions sound more like regular Celestions. I still prefer the V30s on my main cabs but it's cool to have a few lighter cabs on the side.
Posted: Fri Jan 12, 2024 3:08 pm
by JiveTurkey
My biggest problem with the DV (at least on the surface but I am betting those speakers didn't help either) is the semi-open back. My 112s are both open semi-open and I have thought (a time or 37) about converting them to close back.
Posted: Fri Jan 12, 2024 3:10 pm
Yeah that's definitely an issue. I don't like semi open back cabs either.
I have a 2x12 here that was semi open and it sounds much better after I closed it.
Posted: Fri Jan 12, 2024 3:28 pm
by HELSTRUME
Sorry, my current cabs weight that
Posted: Fri Jan 12, 2024 4:15 pm
by screamingdaisy
"I went modelling because amps are too big and bulky"
(hauls in 19" rack, nasa footcontroller, two expression pedals and FRFR monitor)
"Is that so?"
(Puts down Fender DRRI and plugs in)
Posted: Fri Jan 12, 2024 4:32 pm
screamingdaisy wrote:GuitarBilly wrote:you know... a FRFR is an amp. It doesn't matter what trendy name they give it, it has a preamp/input section, a power amp and a speaker. Which = amp.
"Is that so?"
Exactly
"oh but I have 50 amps and 20 cabs models I can choose from"Uses 3 tones.
Posted: Fri Jan 12, 2024 6:43 pm
by JiveTurkey
Posted: Fri Jan 12, 2024 7:08 pm
by Dave
It’s heavy, expensive, and still requires a modeler
Makes sense
Posted: Wed Jan 17, 2024 12:32 pm
by thermionic geek
I think this was intended for touring bands to get the Laney logo back on stage. With a bright LED light on it.
