Hi, I bought this one, but for some reason I can't get the best sound from it. I use a guitar with the recommended distance. I think its the DAW i use most likely. I only can afford a free DAW
Anyone knows this micro? Any advice?
Shurre MV51 microphone
- rock flag and eagle
Re: Shurre MV51 microphone
I've never seen this mic before, but I see it has different settings - are you using the guitar one? Have you tried the flat one?
Also, what driver are you using? Looks like it has it's own driver, make sure that's selected in your daw.
The particular DAW you're using shouldn't really matter at all unless you're using some track template with really whack panning/gain/phase settings
Honestly, that's really not a good mic for recording guitar. I know they claim it can do everything but I'd use for conference calls, podcasting and maybe vocals. It's a bit of a gimmick to be honest.
See if you can return this and get a solid mic like a SM57 and a small audio interface. You should be able to do that for the same amount of money.
Welcome to the fold brother!!! This is the BEST guitar/amp forum on the interwebznet!!!
Are you standing the mic on a table while recording?
Are you recording acoustic guitar or electric guitar?
If electric guitar, what amp are you using?
Can you post a clip?
