Ammoon looper problem
Posted: Thu Oct 31, 2019 3:16 am
by Guitarboris
Hi I have decided to make up a pedal board consisting of a boss GT 1 a boss FS 7 switch and a Ammon looper pedal the problem I have is when I loop on clean then change to lead it changes the sound to lead the looper is last in the chain my amp has no got a send effects on the back of it how do I get over this problem
Re: Ammoon looper problem
Posted: Thu Oct 31, 2019 8:13 am
by clipless bumper
are you switching to the lead channel on your amp?
if so - you would need to stay on the clean channel, and get your dirt/drive from the Boss unit.
Posted: Thu Oct 31, 2019 2:23 pm
by Guitarboris
Hi I am switching to lead on the boss GT 1 I am only playing through a little Roland practice amp
Posted: Wed Nov 13, 2019 6:03 am
That's strange. If you're changing the tones in the GT1 and the looper is placed after it, it shouldn't affect the sound in the looper.
Just to make sure, is your signal chain guitar -> GT1 -> looper -> clean amp?
Posted: Wed Nov 13, 2019 11:31 am
by clipless bumper
Or is it possible that the amp is being overdriven so hard that even the clean tones are breaking up?
Does it do this same thing at lower-than-TV volumes?
Edit - sheesh auto correct fail corrected
Posted: Wed Nov 13, 2019 12:05 pm
by Devin
clipless bumper wrote:Or pass out possible that the ammo is being overdriven so hard that even the flavor times are breaking up?
I was thinking this too - some little practice amps just don't have the headroom to handle a loop and something else on top of it. It's usually pretty easy to differentiate between that sound and a "lead sound", though.
