I just downloaded a bunch of easy to use plugins from Plug & Mix. I heard about them in the Don't Crack newsletter.
I tried out a few and they sound pretty freaking good!!! This is exactly the kind of thing I needed to complete my plug-in collection.
Their are a bunch of guitar foot pedal type fx along with limiters, tape saturator, reverb, etc.
https://www.plugandmix.com
PSA - 50 cool plug-ins for $49.00
Re: PSA - 50 cool plug-ins for $49.00
Here is the list of plug-ins... totally worth the $49.00... it's a no-brainer.
I bought it for the fx not the guitar amp sims.
The fx sound great but, I haven't tried the guitar sims yet.
Ambiosoniq
Improve your stereo image
This plug-in looks like a 10-band graphic EQ but it does much more than that. The old school engineers will recognise the added "Ambience" knob that adds incredible depth to the stereo field.
Ambiosoniq comes equipped with fixed frequencies to boost and cut to achieve the optimum effect you want to get
When used on a stereo track or effects return it adds stereo depth and width to the signal being processed. So it is much more than a simple graphic EQ.
Features
- 10 band EQ : Boost or cut from 12 to -12db at the fixed frequencies.
- Ambisoniq Knob : Mix in the EQ sound with your dry signal for more width and tonal control.
- In : Controls the input level of the plug-in.
- Out : Controls the output level of the plug-in.
American Tweed
The Fender Bassman Sound
Based on the legendary Fender Bassman amplifier, this amp simulation plug-in includes 6 Control knobs, Speaker Emulation with Bypass, Stereo Mode Switch and Boost Switch.
The P&M American Tweed plug-in offers an incredibly realistic Fender Bassman amp sound emulation. From sparkling clean to a full crush tone, warm overdrives and even hard solo leads. Use the six effective controls to create your own Tweed amp-like sounds.
The P&M American Tweed can be used as a complete guitar amplifier...
Features
- Drive : Adds more distortion drive.
- Bass : Adds less or more low frequencies.
- Middle : Adds less or more middle frequencies.
- Treble : Adds less or more high frequencies.
- Selector BTN : Off /On Axis mic for speaker emulation.
Analoger
Vintage Tape & Tube Emulator Plug-in
P&M Analoger brings the classic warmth and character of a tape machine to your studio. It allows you to mix in the sound of tape saturation and crunch from vintage tubes to get the sound of tape.
Press the middle Selector button to get a mixture of both Tube and Tape processing. Use the big Drive knob to dial in pure vintage analog saturation. Move the Lows and Highs knobs to adjust the Low and High end of the signal.
Conveniently a Mix knob is placed in the upper left corner to adjust...
Features
- Drive : Adds less or more tape and/or tube drive sound.
- Lows : Adds more low frequencies.
- Highs : Adds more high frequencies.
- Selector buttons : Choose between Tube, Tape or a mixed Tube-Tape sound.
- Mix : Dry/Wet Mix of the plug-in.
Basspeg
Amp up your Bass
This plug-in is your new go to Bass Amp, built in parallel to the classic Ampeg SVT, it delivers deep lows and warmth to any Bass signal and is indeed very flexible with its parameters to easily contour and control your tone.
Features
- Selectable mic'd cabinets and DI
- Bass, Mid, Treble EQ
- Tube Distortion (Drive)
- Low frequency contour (Deep)
- High frequency boost (Bright)
Brightness
Abbey Road Style Brightness Plug-in
Based on the idea of Abbey Road Studios hardware and used on countless seminal recordings at Abbey Road during the '60s, including almost every album by The Beatles.
Sometimes you just need to boost the brightness of a track and this plug-in gets the job done. Simply select the frequency using the selector buttons and then Boost or Attenuate that frequency by turning the big knob.
The result is an easy-to-use plug-in that can add (or reduce) brightness on any track. Fiip the Clipper switch to keep the signal from peaking.
Features
- Brightness : Adds less or more brightness to your track. + or - 10db.
- Selector buttons : Select the frequency to boost or attenuate: 2.8, 3.6 or 10kHz.
- Clipper : Turns on the built-in Limiter to prevent peaking.
British Tone
The MARSHALL Amp Sound
Based on legendary MARSHALL amplifiers, this amp-simulation plug-in includes 6 Control knobs, Speaker Emulation with Bypass, Stereo Mode Switch and Boost Switch.
The P&M British Tone is an extremely versatile guitar amp plug-in that can deliver anything from sweet sound, warm overdrives to edgy overtone-rich distortions. It features detailed sounding nuances, as well as one of the most musical British amp-like distortion that is never flat or muddy.
The P&M-British Tone can add some serious fire to your sound! The P&M-British Tone can be used as a great guitar preamp or as a full guitar amplifier taking advantage of the built-in speaker emulation.
Features
- Selector BTN : Off (bypassed), Off Axis mic or On Axis mic for speaker emulation.
California Tone
The MESA BOOGIE Amp sound
Based on legendary MESA BOOGIE amplifiers, this amp simulation plug-in includes 6 Control knobs, Speaker Emulation with Bypass, Stereo Mode Switch and Boost Switch.
The P&M California Tone guitar amp plug-in delivers true tube dynamic and feel from warm boost to screaming tube saturation. The P&M California Tone offers a wide range of tonal colors from clean level boost to seething saturation. The California Tone is designed to blend beautifully in your music and add richness and gain to your guitar tone.
Add to this no compromise speaker emulated output and you have the ultimate Overdrive California dream. The P&M California Tone can be used as a simple guitar preamp or take advantage of the built-in speaker emulation for a full guitar amp simulation.
Features
Chorus Ensemble
Deep Chorus Ensemble Effect
An easy to use chorus ensemble effect. Your go-to plug-in for quick, lush sounding chorus effects. Use the knobs to quickly dial in color and stereo width while selecting the general rate of the chorus below.
You can choose from Slow, Mellow or Fast chorus rate. Turning the big knob dials in the overall FX Level while you can adjust the signal’s Input and out put level. The result is one of the best sounding Chorus Ensemble plug-ins on the market that is a breeze to operate.
Features
- FX Level : Adds less or more Chorus to your track.
- Delay : Increases or decreases the timing of the chorus effect.
- Color : Changes the tone of the chorus effect to be darker or brighter.
- Stereo : Controls the stereo width of the effect.
- Selector buttons : Select Slow, Mellow or Fast rate of chorusing.
Clarisonix
Sub Bass and Harmonics Enhancer
The Sub bass and Harmonics Enhancer. Use this on any track where you want to achieve a thunderous low end or punchy presence. Perfect for making kick drums sound huge and creating earth-shaking basslines.
The Sub Mode Selector buttons allow you to choose a frequency range to boost. The Lo Focus knob boosts low end punch while the Clarity knob gives you more definition and snap. The Clarisonix is the ultimate plug-in to extend your low-end and achieve impressive bass lines.
Features
- Sub Level : Adds less or more Sub Level.
- Lo Focus : Boosts Low frequencies.
- Clarity : Adds more high frequencies.
- Selector - Choose between Sub Modes 1, 2 & 3. Each mode emphasizes a different sub frequency.
Classic Flanger
Silky Smooth Flanger Effect
A silky smooth flanger effect that can go from subtle to extreme in an instant. This unit models Classic, M-Tron and Stompbox flanger models that are still the industry standards.
Guitar players will find the P&M Classic Flanger especially easy to use because of it's simple, familiar layout. Choose from 3 different Flanger models and then use the Depth and Feedback knobs to adjust the strength of the effect.
The big Speed knob adjusts the rate of the flanger and can be synched to your master tempo by flipping the Sync switch below.
Features
- Speed : Changes the speed of the flanging effect.
- Depth : Changes the depth of the flanging effect.
- Sync : Synchronizes the speed (rate) of the flanger to your host BPM.
- Feedback : Adds positive or negative feedback.
- Selector buttons : Choose between Classic, M-Tron or Stomp flanger modes.
Classic Phaser
Vintage Multi-Stage Phaser Effect
This is an extremely musical vintage multi-stage phaser effect. Select between the different stages of phasing and sync the results for out-of-this-world modulations.
Each of the stage Selector Button determines the number of notches/peaks in the sound, affecting the general sound character.
The big Speed knob adjusts the rate of the phase and can be synched to your master tempo by flipping the Sync switch below.
Features
- Speed : Changes the speed of the phaser effect.
- Frequency Range : Changes the depth of the phaser effect by increasing its sweep range.
- Sync : Synchronizes the speed (rate) of the phaser to your host BPM.
- Resonance : Adds resonance to the sound of the phaser, causing it to ring out more.
- Selector buttons : Choose between 4, 6 and 8 Stage modes;
Cool-vibe
Hendrix's Uni-Vibe based Effect
Based on the Uni-Vibe used by Jimmy Hendrix. This is a favorite of guitar and keyboard players looking to add some very special vocal character to their performances.
Select from sync-able speed and vibe mode and enter a whole new world of tone. Use the Selector Buttons to choose from 3 unique Vibe Modes: Sweet, Mellow and Deep. Increase the strength and stereo image of the effect by turning the Intensity and Width knobs.
Use the big Speed knob in the middle to increase the rate of the effect. You can also sync the Cool-Vibe to your master tempo by flipping the Sync switch.
Features
- Speed : Changes the speed of the Cool-Vibe effect.
- Intensity : Changes the intensity of the effect.
- Sync : Synchronizes the speed (rate) of the Cool-Vibe to your host BPM.
- Width : Increases the stereo width of the cool bar effect.
- Selector buttons : Choose between Sweet, Mellow and Deep Vibe Modes.
Degradiator
Bit Crusher Style Plug-in
This Bit Crusher style plug-in will mangle and degrade your sound to a whole new level. You can use it to dirty digital saturation to your tracks and create wild down-sampled textures.
Degradiator provides three levels of bit crushing mayhem and a bandpass filter to achieve vintage radio telephone effects.
Features
- Crush : Determines the bit depth (24bit to 1bit).
- Telephone : A bandpass filter that sweeps up to 20kHz.
- Down-Sample : Selects sample rate ( 44.1, 48k, 88.2, 96k).
Deluxe Tilt
Extreme EQ when needed
The Deluxe Tilt is a unique EQ that simultaneously boosts and cuts by shifting the EQ curve around a center frequency of your choosing.
The result is a natural and effortless way to get a subtle or an extreme EQ setting with the turn of a knob.
Use the Deluxe-Tilt to warm up or cool off a track to add contrast in your mix or add clarity where you need it.
Features
- TILTING : Turning the knob to the right not only acts as a treble boost, but also a bass cut, while turning it left performs the opposite function.
- NORMAL : This mode has a narrow Q.
- MELLOW : This mode has a moderate Q.
- LUSH : THis mode has a wide Q.
Digital Plate
EMT Based Gold Plate Analog Reverb
Based on the EMT "Gold Plate" Analog 2-ch Reverb. This reverb can give your digital tracks more depth, more space and more soul.
Don't let the easy to use interface fool you, this is a deep sounding reverb plugin that can stand up to any vintage hardware unit. Adjust the big Time knob to increase the length of the Reverb effect.
Then you can dial in the tone of the Reverb effect by adjusting the Color knob. Finally, use the Mix and Level knobs to dial in your dry-to-wet mix and over all balance.
Features
- Time : Increases the time of the Reverb effect.
- Color : Changes the tone of the reverb effect to be darker or brighter.
- Level : Controls the output level of the plug-in.
Digital Reverb
Eventide based Reverb
Based on the Eventide Reverb 2016, this plug-in sounds amazingly natural and works especially well on drums. Choose between small, medium and large room size for convenient reverb effects sculpting.
The ER Level knobs allows you to control the levels the Early reflections while Lows and Highs dial in the tone of the reverb. The big Decay Time knob controls the length of the reverb while the mix and output knobs reside in the upper left and right hand corners.
Features
- Decay Time : Increases the time of the Reverb effect.
- ER Level : Controls the early reflection levels.
- Selector buttons : Choose between Small, Medium or Large room sounds.
Dimension 3D
Roland Dimension D Type Effect
Based on the famous Roland SDD320 - 'Dimension-D' released around the late 70's. This unit adds the highly sought after detuning effect heard on countless classic rock records and that continues to be used on modern club tracks.
Press one of the 3 Selector Knobs to Choose between 3 detuning modes and then adjust the overall strength of the effect with the big Detune knob. Use the In and Out knobs at the top to adjust the signal input and overall out.
Features
- Detune : Gives you less or more of the classic detune effect.
- Selector buttons : Choose between D1, D2 or D3 for 3 different levels of chorusing.
Distorted
Smooth Distortion Effect
P&M Distorted is a smooth distortion effect with versatile EQ and tone controls. Add this to an track where you need extra crunch or grit. Use the built in EQ for additional tone sculpting.
The Color knob allows you to dial in the perfect tone for your distortion while the Mix knob in the upper left corner allows you to adjust the dry-to-wet mix.
Features
- Low Cut : Cuts all frequencies below a certain point.
- Highs : Cuts all high frequencies above a certain point.
Echoflex
Echoplex Based Tape Delay Effect
Based on the famous Echoplex guitar pedal. This tape delay effect was used by almost all of the most notable guitar players of the 60's and 70's eras.
The echo timing is tempo sync-able and can be switched from stereo to mono. Use the tone and variation knobs to achieve creative feedback echoes. The sustain knob increases the feedback for creating endless delay tails.
Turning the big Echo Time knob during playback or by using automation can cause some interesting tape-style effects that are popular in dub and experimental music.
Features
- Echo Time : Changes the echo time from 0001 ms to 1000 ms.
- Tone : Determines the tone of the echoes.
- Variation : Emulates the slight variations of tape-based delay.
- Sustain : Increases the amount of feedback.
- Sync : Synchronizes the speed (rate) of the EchoFlex to your host BPM.
- Ping-Pong : Allows to switch from centered to ping-pong delay.
Electro Optical
Two Channel Electro-Optical Compressor/Limiter
This is a two channel electro-optical compressor/limiter designed for the utmost in transparency, detail and versatility.
The plug-in's soft-knee design offers smooth, effortless dynamic control with the ratio adjustable from light compression to brickwall limiting. The Response knob adjusts the compressor's attack while the release is set automatically.
Adjust the Input Gain to increase the amount of compression and Output Gain to increase the overall level. The Selector Buttons choose the frequency to activate the internal sidechain features.
Features
- Input Gain : Increases the amount of signal sent to the compressor.
- Response : Determines the speed at which the compressor reacts to the incoming signal.
- Output Gain : Increases the level of output for the compressor.
- Soft Knee : Smooths out dynamic control.
- Selector buttons : Choose between Off, 100 or 200 Hz to activate the internal frequency sidechain.
Electro Q Tone
This plug-in can produce some serious filtering auto filtering action for rich and funky sounding results.
Q-Tone sounds great on drums guitars and bass and it's unique envelope controls allow you to modify the filter's behavior with ease.
Features
- MIX : Dry/Wet control.
- FILTER TYPE : Filter mode control, blends between lowpass, bandpass and highpass modes.
- CUTOFF : Center frequency control for the filter.
- RESONANCE : Resonance control for the filter.
- ENVELOPE ATTACK : Controls the time taken by the filter to sweep from Center frequency to - Center + Amount.
- ENVELOPE DECAY : Controls the time taken by the filter to restore initial state.
- SWEEPER : Controls the sweep range.
Gatevador
Close the Gate
Gatevador allows you to easily and quickly control excess bleed and noise on your source material, and enhance and expand the good stuff! With minimal controls as per all our P&M plug-in designs, you can gate and expand to your hearts content.
Features
- Gate
- Expander with set ratios (Exp 1 and Exp 2)
Granulizer
Granular Processing Plug-in
Granulizer is an out of this world effect that will give you some unique results that can only be achieved with granular processing.
This special granular delay effect splits incoming sounds into small grains and then transforms and mixes them up.
This plug-in can give you dark, disturbing sounds as well as strange hi-pitched tones.
Features
- GRAINS RATE : Controls grains repetition speed
- GRAINS DENSITY : Duration control for the grains. The higher duration the more overlapping grains generated, increasing sound density
- GRAINS FEEDBACK : Controls amount of the output signal fed back to the input
- GRAINS LOWPASS : Lowpass filter cutoff control, which inserted into the feedback path. Simulates spectral loss in the feedback path
- TUNE PITCH : Grains transposition control. Range -12, …, +12 semitones
- TUNE RND PITCH : Controls amount of random transposition added to each grain
Liquid Air Q
EQ with presence
This unique plug-in offers an easy way to breath more life or "air" into any track.
It comes with three adjustable lower and mid frequency bands for dialing things in, so you have full control over which frequency you want to highlight.
The additional high band EQ is actually a shelf with adjustable frequency AIR Band controlling sound presence and transparency.
Features
- LOW FREQ : Center frequency of the Low Band. Range 40, …, 150 Hz.
- LOW GAIN : Gain control for the Low Band.
- MID 1 GAIN : Gain control for Mid1 Band (the band below 1 kHz).
- MID 2 GAIN : Gain control for Mid2 Band (the band between 2 and 3 kHz).
- AIR SHELF : Gain control for the AIR Band (High frequencies).
- AIR FREQ : Bandwidth control for the AIR Band.
Lo-Fi
Add digital filth to your tracks
Never before has there been a grungier, more filthy Lo-Fi plug-in.
This plug-in takes Lo-Fi to the next level by combining Bit Depth, Decimator and Noise to produce hardcore redux distortion tones.
P&M Lo-Fi can be used on a variety of sources and it especially sounds good on bass, guitar, and rhythmic material. Edgy and unpredictable, use this plug-in any time you want to add some nice digital filth to your tracks.
Features
- MIX - Dry/Wet control.
- STEREO - Widens the stereo field of the effect.
- BIT DEPTH - Reduces the bit depth from normal to Distroy
- DECIMATOR - Down-samples your signal until it is completely obliterated.
- NOISE - Adds noise and hiss to your signal
Loudbass
Stereo Bass Booster
Want your low end to be as impressive as possible? Got a project to mix for the dancefloors and you are missing the "thump" you need to compete?
This monster plug-in can really fatten up you low end and give you a nice stereo field enhancement at the same time.
Choose the bass frequency you want to boost or cut, then expand the stereo width or narrow it to a pure mono signal.
Features
- FREQ Hz : Adjusts the operating low frequency band width.
- BOOST Db : Control additional boost applied to the low frequencies. Center frequency depends on FREQ value.
- WIDTH : Stereo width control of the low frequencies. Can both expand or narrow the bass image.
Ls Rotator
Great Leslie
This plug-in gives you the classic sound of a Leslie rotating speaker.
The speaker has two elements - the lower and upper rotor. This effect works really well on guitars, keyboards and even vocals sometimes.
Add some drive for a really gritty tone and flip the switch for slow or fast rotation speeds.
Features
- SLOW-FAST SWITCH : Speed control for the rotating speaker.
- BASS : Speed control for the low frequency rotor.
- TREBLE : Speed control for the high frequency rotor.
- ACCEL : Controls the acceleration of the rotors when changing their rotation speed.
- BALANCE : Controls the ratio between the output produced by the lower and upper rotors.
- SPREAD : Controls the width of the stereo image.
- DRIVE : Controls amount of saturation applied to the input sound.
Magic Queen
The VOX Amp sound
Based on legendary VOX amplifiers, this amp simulation plug-in includes 6 Control knobs, Speaker Emulation with Bypass, Stereo Mode Switch and Boost Switch.
The P&M Magic Queen is a unique type of overdrive/distortion guitar amp plug-in that was designed to emulate the distortion characteristics of Vox tube amps. The PM-Magic Queen is an overdrive plug-in that provides a wealth of dynamic overdriven tones with superior tonal control.
The PM-British Tone produces an exceptional natural response. The PM-Magic Queen can be used as preamp or take advantage of the built-in speaker emulation for a full guitar amp simulation.
Features
Monster Boost
A Signal Booster with Warmth
This plug-in is a signal booster that adds harmonics and warmth to your tracks.
The Monster Boost has that magic coloration that can be used on everything, from Drums, to Vocals, to entire mixes. This is far from a transparent effect, rather it adds mojo and feel to any instrument or voice.
Features
- Booster : Adds gain to the output without overloading the audio.
- Warmth : Adds lows frequencies for a warmer sound.
- Harmonics : Adds harmonic distortion and punch.
- Details : Adds brilliance or high frequency.
- Selector Buttons : Choose between Natural, Lush and Mellow to control the overall tone.
Moogy Filter
Classic vintage filter pedal
Having a P&M Moogy Filter is like bringing home a classic vintage filter pedal for use on all of your tracks.
This plug-in’s great sounding filter can be driven with it’s built in saturation for crunchy tones and it also has an envelope follower to give that extra bite.
P&M Moogy Filter has three filter modes: Low-Pass, High-Pass and Band-Pass, which makes it extremely versatile for use on all kinds of material: Whether its percussion, keys, vocals or as a DJ effect, Moogy Filter will make your tracks sing.
Features
- CUTOFF - Controls the cutoff frequency of the filter.
- SATURATION - Drives the filter and causes crunch distortion tones.
- RESONANCE - Determines the strength of the filter at it’s cutoff.
- TRIGGER - Sets the speed of the filter envelope.
- DEPTH - Sets the depth of the filter envelope.
- FILTER MODE - Choose from Low-Pass, High-Pass or Band-Pass filter types.
Multi-Tap Delay
Multi-tap madness
P&M Multi-Tap Delay brings a new twist to delay plug-ins.
Set your general rate with the big speed knob and then prepare yourself for Multi-tap madness as you can adjust the precise position and pan of all 5 delay taps.
The results can vary widely: from cascading delay lines to resonant robotic tones, to dreamy echo drones, this plug-in can do it all. P&M Multi-tap sounds amazing on guitar, vocals, synths and anything else you feed it.
Features
- SPEED - Controls the timing of the initial echo.
- SYNC - Allows you to sync the delay with your master tempo.
- COLOR - Dials in the brightness or darkness of the echo.
- REPEAT - Turns up the feedback of the effect.
- POS - Sets the position of the playhead for each individual delay tap.
- PAN - Sets the pan of each of the 5 delay taps.
- LEV - Sets the level for each delay tap.
Ob La Wah
The Virtual WAH-WAH Pedal
Don't have a wah-wah pedal in the cupboard? Don't worry, OB LA WAH will step in and provide the "vintage" sounds you need with all the possibilities that full automation gives you.
Based on the emulation of a popular Wah-Wah pedal, this effect responds to the dynamics of the input sound.
The result is a funky and psychedelic effect that sounds great on guitars and keys. Use this colorful effect to modulate any sound source and make your tracks sing.
Features
- FILTER CENTER : Center frequency control for the filter. The control is equal to the pedal pressure level,
- ENVELOPE SPEED : Controls the time taken by the filter to sweep from Center frequency to Center + Depth and back,
- ENVELOPE DEPTH : Controls the sweep range,
- ENVELOPE SENS : Controls envelope sensitivity. Used for tuning to match input sound level.
Octaplexer
Octaver Divider Plug-in
Missing some extra low end in your mix? Want the main guitar or synth riff to have a bass duplicating it to give a really "solid" feel?
This effect mixes input sound with two generated signals that are one and two octaves below original pitch.
Note that the effect works great only with single notes, not chords. For best results Octaver should be inserted before effects chain, especially before reverbs and delays.
Features
- DRY : Controls the level of the input sound in the mix.
- 1 OCT : Controls the level of the sound one octave below in the mix.
- 2 OCT : Controls the level of the sound two octave below in the mix.
- FILTER : Filter control used to adjust timbres of the generated signals.
Pitch Me
Dual Pitch Shifter
Pitch Me is your dual pitch shifter plug-in, developed with a view to the formidable H910 units of old. Independently control left and right pitch values for added width and chorus effect to your vocals and guitars and synths, just like those artists from AC/DC to Zappa.
Features
- Independent left and right pitch shifting
- Link control for setting opposing +/- values each side. Offset remains as you adjust
Psycho Ring
A unique Ring Modulator
This is a ring modulator with attitude. The effect multiplies and mixes the input sound with a special signal, generated by the internal oscillator.
When you have tried every EQ in your plug-in set and you need a extra something to give some "personality" to a sound, Psycho Ring will probably give that extra "indentity".
The result is a unique sound, saturated with lots of different harmonics.
Features
- FREQUENCY : Frequency control for the internal oscillator.
- SHARPNESS : Controls amount of the saturation inside the internal oscillator.
- FEEDBACK : Controls amount of FM feedback applied to the input signal.
Retro Compressor
Warm Vintage Compressor
P&M Retro Compressor is a compressor that has a vintage sound with those retro-looking controls. Quickly dial in your compression settings with the easy to use knobs.
Use the R-2, R-4 and R-8 buttons to achieve a more extreme compression sound. Use the traditional attack and Release knobs to dial in how the compressor reacts to incoming signal while using the big Compression knob to control the level of Gain Reduction.
Trim adjusts the input while the Make up gain controls the output of the overall sound.
Features
- Compression : Determines the amount of gain reduction applied to the input signal.
- Attack : Adjusts the speed of the compressor’s attack.
- Release : Adjusts the speed of the release of the compressor.
- Selector buttons : Choose between R-2, R-4 and R-8 to increase the release duration.
- Trim : Controls the level of the input signal.
- Make Up : Controls the output level of the plug-in.
Retro Equalizer
API Like Classic EQ
Based on the API 550A this classic EQ is a mainstay in professional studios worldwide. Dial in your sound in no time by finding the frequency you want, then boost or cut to taste.
You can also select whether or not to use a shelf or bell curve on the low and high frequencies with the Selector Buttons. The middle button narrows the width of the MF band, giving you more precision controlling the middle frequency spectrum.
Features
- Top 3 knobs : Determine the current frequency to boost or cut.
- Bottom 3 knobs : Gain knobs for Low Middle and High frequencies chosen above.
- Selector buttons : Choose between Low Shelf/Band Pass, Band Pass/Notch/ and High Shelf/Band Pass;
Retro Filter
Great Sounding Retro Filter
Retro low pass, band pass and high pass filters which add that special mojo to a track. This plug-in sounds great on guitars, bass or vocals - anywhere there is a need for creative tonal sculpting.
Dial in the overall effect strength with the big Presence knob while using the kHz knob to determine frequency you are accentuating or deemphasizing. The High pass and Low Pass knobs help to shave off unwanted frequencies on the Low and High ends.
Features
- Presence : Increase or decrease the sound of the filters on your track.
- High Pass : This knob filters out frequencies below the specified point.
- kHz : Determines the width of the band pass filter.
- Low Pass : This knob filters out frequencies above the specified point.
- Selector buttons : Choose between Low Shelf/Band Pass, Band Pass/Notch/ and High Shelf/Band Pass.
Retro Limiter
Great Sounding Limiter
This is a simple, great sounding limiter that you can use to control the dynamics of any track or mix. Additional selector controls allow you to choose between Limiting and Compression modes.
The big Limit Level knob in the middle controls the amount threshold while the Recovery knob changes the time that the Limiter returns to zero. Trim level adjusts the signal input level and the Make Up knob controls your overall output level.
Features
- Limit Level : Determines the amount of Gain Reduction on the input signal.
- Recovery : determines the amount of time it takes for the limiter to recover.
- Selector buttons : Choose between Limiter, Comp 1 and Comp 2 settings.
S-Tractor
De-Ess your Vocals
S-Tractor is your new de-esser; with just three parameters for quick and easy control of your vocal T’s, P’s. Adjust the frequency, threshold and amount values to tame those harsh and nasal tones. Simple!
Features
- Easy to use De-esser
- Sidechain listen for precise tuning of frequency removal
Screamer
Hardcore Screaming Distortion
If you were looking for something to make one of your tracks be ultra-present, this is the plug-in you need.
This wild effect uses a heavily overloaded lowpass filter for generating a 'screaming' sound.
We recommended to use this on dry sounds only as the effect is very extreme. This hardcore distortion effect allows you to choose between 3 different distortion modes and also can act as a low pass filter as well.
Features
- CUTOFF : Frequency control for the lowpass filter.
- SCREAM : Controls amount of the internal saturation.
- MODE 1-3 : Three types of distortion.
- OUTPUT : Adjusts the output level.
Stereolizer
Stereo Width Enlargement
This effect provides a unique way to get the most width out of your stereo panning. Want to get that stereo synth pad to sound like its coming from outside your speaker placement, this is the plug-in to do it.
The Stereo Width knob adds more spacial imaging while you can also choose the mix balance and center position of the track in the stereo field.
Features
- WIDTH : Controls the stereo image width. Can be used for expanding or narrowing the stereo base.
- CENTER : Adjusts the center of the entire stereo image.
- BALANCE : Adjusts the relative level of left and right channels.
Talking Tone
Talk Box and Vocoder
Do you want to add something really special into your Mix? This effect simulates the way voice formants are synthesized and will get your tracks "talking".
You can achieve some very interesting and musical effects with a talk box, especially for classic vocoder sounds on the lead voice. This effects unit also sounds great on drums, guitars, and bass, adding an effect that really "communicates".
Features
- MOUTH : Blends between different vowels.
- PITCH : Adjust the vowels pitch.
- ENVELOPE : Controls the speed the effect responds to sound dynamics.
- DEPTH : Controls the depth the effect responds to sound dynamics.
ToneStack
6 Classic amp tones
P&M Tone-Stack delivers the guitar amp tone you’ve been yearning for ever since you sold your amp on craigslist.
Tone-Stack includes 6 classic amp tones as well as a cabinet switch and tone modeling controls for precise control over your screaming guitars, bass, synths, vocals and beyond.
Use the drive knob for extra grit and boost your lead lines into the stratosphere.
Features
- DRIVE - Controls the drive amount of the amp section.
- AMP TYPE - Select from 6 different classic amp types.
- CONTOUR - Switches on extra tone-shaping for added control.
- CABINET - Switches on the cabinet emulator for authentic guitar amp mayhem.
- BASS - Dials in the low end of the effect.
- MIDDLE - Adjusts the mid-range of your tone.
- TREBLE - Adds bite to your signal.
Transcontrol
SPL based Transient Designer
This Transient Designer is known for creating punchy drums and can be applied to virtually any other signal as well. Apply this plug-in to any percussive element and you'll hear it cut through any mix.
Place this plug-in on a kick or snare track and adjust the Attack and Sustain knobs until you hear the snap of your drum and nice sustain level. Then turn the big Output Gain knob to boost or attenuate you newly transient designed sound.
Features
- Output Gain : Increases or Decreases the output of the plug-in.
- Attack : Amplify or attenuate the transients of incoming signals.
- Sustain : Amplify or attenuate the sustain of incoming signals.
Tremolo Pan
Versatile Tremolo and Panning Effect
A versatile tremolo and panning effect, this plug-in gives your tracks the movement and life that they may need. This device allows you to choose from Sine, Triangle and Square algorithms so your tremolo sound can be silky smooth or become more agitated jagged sounding effect.
Adjust the Depth and Width knobs to increase the effect’s strength and stereo imaging. Turn the big Seed knob to change the rate of the tremolo and flip the switch to synchronize the effect to your DAW’s master tempo.
Features
- Speed : Changes the speed of the Tremolo Pan effect.
- Depth : Changes the depth of the effect.
- Sync : Synchronizes the speed (rate) of the Tremolo Pan to your host BPM.
- Width : Increases the stereo width of the Tremelo Pan effect.
- Selector buttons : Choose between Sine, Triangle and Square Tremelo Modes.
Ultramaxit
Easy to Use Level Maximizer Plug-in
Ultramaxit is a simple to use Maximizer powerhouse that is great for bringing up the overall level of a mix or achieving heavy compression settings.
Apply this plug-in to your master bus and achieve the overall broadcast/mix level you need, without distortion. The big Threshold knob controls the amount of compression.
While the Release knob changes the speed of the compressors release. Adjust the Out Ceiling knob to control your overall output level.
Features
- Threshold : Gives you less or more gain reduction.
- Release : Determines the speed at which the compressor releases.
- Out : Controls the maximum output level of the plug-in.
Vibrator
Add some Vibe to your sounds
Vibrator; like the Uni-Vibe, add movement to your mixes and instruments/sounds. Create spacial width effects and shimmer. Tuck the effect under your source with parallel mix control for added flavour to static, monophonic and dull sounds.
Features
- Vibrato Speed
- Intensity
- Width
- Host tempo sync control
Vinylizer
Get that Vinyl Sound
This Lo-Fi effect achieves the classic vinyl record sound.
Give your tracks that old school flavor by adding a touch of noise dust and scratches to the mix.
These analog artifacts will add life and warmth to your tracks, just like the old records from back in the days when your record-player had "soul".
Features
- NOISE MIX : Controls the amount of vinyl noise added to the mix.
- NOISE TONE : Adjusts the noise shape.
- DUST RATE : Controls the amount of dust on the emulated vinyl disk.
- DUST MIX : Controls the level of the dust effect added to the mix.
- SCRATCHES RATE : Controls the amount of scratches on the emulated vinyl disk.
- SCRATCHES MIX : Controls the level of the scratches effect added to the mix.
Vowel Comb
Vowel overtone comb filter
P&M Vowel Comb offers a unique spin on filter plug-ins.
This unconventional effect allows you to add vowel overtones to any source material causing your rhythms to come alive, your guitars to speak and your bass to growl like a beast.
The big vowel knob easily dials in the vowel sound while Formant Shift, Envelope and Resonance give you additional sound shaping controls. The result is a talking comb filter like no other.
Features
- VOWEL - Dials in the vowel frequency and emits a vocal-like quality.
- SHIFT - Changes the character of the tone from lower darker tones to brighter.
- ENVELOPE - Controls the speed of the envelope’s bite.
- DEPTH - Controls the depth of the envelope.
- RESO - Boosts the strength of the Vowel frequency.
Ambiosoniq
Features
American Tweed
Features
Analoger
Features
Basspeg
Amp up your Bass
Features
Brightness
Features
British Tone
Features
California Tone
Features
Chorus Ensemble
Features
Clarisonix
Features
Classic Flanger
Features
Classic Phaser
Features
Cool-vibe
Features
Degradiator
Features
Deluxe Tilt
Features
Digital Plate
Features
Digital Reverb
Features
Dimension 3D
Features
Distorted
Features
Echoflex
Features
Electro Optical
Features
Electro Q Tone
Features
Gatevador
Close the Gate
Features
- Gate
Granulizer
Features
Liquid Air Q
EQ with presence
Features
Lo-Fi
Features
Loudbass
Stereo Bass Booster
Features
Ls Rotator
Great Leslie
Features
Magic Queen
The VOX Amp sound
Features
Monster Boost
Features
Moogy Filter
Features
Multi-Tap Delay
Multi-tap madness
Features
Ob La Wah
Features
Octaplexer
Features
Pitch Me
Dual Pitch Shifter
Features
Psycho Ring
Features
Retro Compressor
Features
Retro Equalizer
API Like Classic EQ
Features
Retro Filter
Features
Retro Limiter
Features
S-Tractor
De-Ess your Vocals
Features
Screamer
Features
Stereolizer
Features
Talking Tone
Features
ToneStack
6 Classic amp tones
Features
Transcontrol
Features
Tremolo Pan
Features
Ultramaxit
Features
Vibrator
Features
- Vibrato Speed
- Intensity
- Width
Vinylizer
Features
Vowel Comb
Features
