draelyc
Post by draelyc »
_______
MY REVERBNATION PAGE!
trey85stang2
Re: Sequencing drums in GarageBand?
Post by trey85stang2 »
draelyc
Post by draelyc »
trey85stang2 wrote:you can do it, a midi keyboard will help, but you can do it all in the piano roll. Its tedious but can be done. I personally use an alesis sample pad pro, play the drum parts (the best I can) then fix my sloppy playing in piano roll
Dig. Thanks! :thu:
_______
Post by Marc G »
RUBATO wrote:Step 1) post 5 drum sample comparison videos in the most confusing format you can manage.
what version are you using?
draelyc
Post by draelyc »
I R noobzors, lol.
_______
Post by Marc G »
draelyc
Post by draelyc »
Marc G wrote:depending on your version there will be a Garageband Drummer you can insert, it will automate the drums for you and you should be able to export it to Midi and then apply a drum kit to it and THENNNN just modify it if need be... I know you can do that in Logic at least
Oh, man. :-/ So many steps...
_______
neilrocks25
Post by neilrocks25 »
This.
neilrocks25
trey85stang2
draelyc
Post by draelyc »
Much appreesh, y'all! :thu:
_______
trey85stang2
draelyc wrote:Not really at a point where I can think about stepping up to a bigger, better DAW ~ and I've barely scratched the surface of GB so far, anyway. :idk:
draelyc
Post by draelyc »
_______
trey85stang2
draelyc wrote:...
JerEvil
Post by JerEvil »
www.groovemonkee.com
https://dunkysndemos.com
draelyc
Post by draelyc »
JerEvil wrote:GB will do exactly what you are asking. If you use the Drummer feature, use the kittle controller ball to get an approximation of what you want. Then you can always convert it to a midi track and adjust it from there if you want. For your needs I am sure the Dummer will be fine. Experiment with different "drummers" and kits.
http://www.groovemonkee.com
I haven't had a chance to try this yet, but I will ~ much appreciated, Jer! :thu:
_______
I just watched some quick tutorials on how to do this in Garage Band. So I know how, but I’m not gonna tell you. :nope:
draelyc
Post by draelyc »
RUBATO wrote:I just watched some quick tutorials on how to do this in Garage Band. So I know how, but I’m not gonna tell you. :nope:
[video]https://youtu.be/Rzu6hdfZ2V4[/video]
_______
K-Bizzle
Post by K-Bizzle »
I use Garageband on my ipad for all my writing because of its ability to be quick and easy with drums.
Doesn't have most of the tools people want in a DAW but I use it for getting ideas laid down and clearly communicated. Doesn't need to be any better than it is.
So with that said what I always do is a combo of manually programming the kick and snare (and sometimes crashes if needed) and using the built in Drummers to handle everything else (fills, tom work, almost all the symbols).
Its easy to "program" the kick and snare on iPad because I just play out the rhythm for each part. Fix it where needed, then loop. After that add the drummer and usually have the drummer synced to the bass or rhythm guitar. Sometimes I sync it to the kick/snare part.
Anyway I write songs FAST this way and the software mostly stays out of my way which is why I like it. Someday soon I'll use a more serious DAW but I love the flow on the ipad with garageband for writing.
Maps:
Cabs:
Of all the dead threads to be reincarnated... That or Drae has died and been reincarnated as a Chinese bot named MonikaLarkin. :rofl:
Edit: Spellung is hardt
K-Bizzle
Post by K-Bizzle »
itchyfingers wrote:Of all the dead threads to be reincernated... That or Drae has died and been reincarnated as a Chinese bot named MonikaLarkin. :rofl:
Wow, obviously I did not fucking notice.
Captain observant over here, I guess I always assume if its under active/view new posts its actually new and not some weird necro bot bump.
Maps:
Cabs:
Cmon, K - admit you got excited at the thought of a token female joining the fray :nope:
K-Bizzle
Post by K-Bizzle »
G-SPACE wrote:Cmon, K - admit you got excited at the thought of a token female joining the fray :nope:
Too old any married for that unfortunately.
Also
Maps:
Cabs:
Wasn't calling you out, KB I promise! The only reason I noticed is because I hadn't seen a Drae-which-minutiae-is-better thread in like a year. :lol:
