...and no sound at all now
Post by Elessar [Sly] »
Right... well I am officially stressed with Cubase 6. I was able to record audio, then I couldn't even import audio, and now I can't record either. I can't tell what is wrong everything SEEMS to be set correctly :cry: haha at my wits end! Considering downloading reaper, but what is the point it is possible I'll have the same problem...
Baxandall
Re: ...and no sound at all now
Post by Baxandall »
Hardware issues? Have you tried listening to a music file without the daw?
Baxandall wrote:Hardware issues? Have you tried listening to a music file without the daw?
Yup, doesn't work =/
Baxandall
Post by Baxandall »
Boo. Sounds like hardware and not Cubase.
Baxandall wrote:Boo. Sounds like hardware and not Cubase.
Hardware is working fine... getting sound and signal from it on it's root program (that I have tried both on AND off whilst using cubase). Again, I had it working with cubase and now it isn't.
:idk: which one is it? That's kinda confusing lol
So if you turn on your computer and open up a sound file, does it play? Leave Cubase out of the equation here for a min
Devin wrote:So if you turn on your computer and open up a sound file, does it play? Leave Cubase out of the equation here for a min
Yeah it plays, then when the interface it sound files won't play through the laptop (obviously), but they don't through the interface either. But, I am still getting signal through the interface in the program it came with, and when I check audio devices in control pannel there IS signal. Very confusing :idk:
That is weird. What kind of interface are you using, and what OS? If you're using the driver that came with the DAW, maybe try ASIO4ALL instead?
Ahh I need to get a decent interface... I'm using a VERY crappy Line 6 UX1 or something. I want to get the Akai EIE PRO.
