BOTR 2023: Best Large Pedal Board Rig (8 or more pedals)
Forum for our annual Battle Of The Rigs competitions
Poll ended at Sat Jul 15, 2023 10:06 am
spawnofthesith
1
5%
bubbastain
1
5%
rock flag and eagle
1
5%
9%
9%
LukeBurke1
4
18%
duncan
2
9%
greatmutah
2
9%
Stratsouldier
7
32%
Total votes: 22
greatmutah
Site Moderator
Post by greatmutah »
Post dem large bois here. Bonus points for organization. Ok not really but presentation sways votes.
Metropoulos Metro-Plex
Orange Rockerverb 50 MK III
Fender '76 Vibrolux Reverb
Marshall 1960A w/ Greenbacks
spawnofthesith
Re: BOTR 2023: Best Large Pedal Board Rig (8 or more pedals
Post by spawnofthesith »
Front: Dunlop switchless bass wah > Mu Tron Micro Tron IV> Korg pitch Black > keeley compressor plus > Mu tron Phasor III > boss sd-1
Loop: EQD Afterneath (with moog expression pedal) > Boss Re-202 space echo > boss rc-500
bubbastain
Post by bubbastain »
I use this pedal board for three different setups. In the picture here it's going out from the AMT M1 into the side jack that then goes into everything to the Left of the blue pedal in stereo and into a Mosvalve SS power amp. If I'm running two tube amps I take out the M1 and go from the SD-1 into the front of amp 1. Then then use the side jacks amp 1's loop and the second stereo out jack of the 720 looper into amp 2's return. Or I can run it in mono into just one amp.
rock flag and eagle
Post by rock flag and eagle »
I swap out a few things , but for the most part this is usually my board. Guitar goes into Keeley Plus compressor > JHS unicorn > demon fx king of drive > keely moon fuzz > Wampler Velvet fuzz > evh 5150 overdrive > front of amp
The rest is running in my loop - digitech Luxe > keeley caverns > boss rt20 rotary
Y'all know how it sounds
Analogman Sunface NKT275 White Dot Normal Gain - Ernie Ball MVP volume pedal - Fulltone Deja Vibe MkII - Fulltone OCD V1.4 - Stomp Under Foot Red Army - Origin Effects Cali76 - Skreddy Echo
LukeBurke1
Post by LukeBurke1 »
Underneath the board is a re-housed ISP Decimator G-String II, Source Audio Neuro Hub, and a 2-channel remote true bypass looper (adds 2 extra loops to the ES-5).
Gibson Les Paul Traditional Pro II
Gibson SG-3
Gibson Les Paul Special
Vox AC30HWH
Janice Cabs 2x12 (Creamback 65s)
Good Deals with: rleechb, _ej_, phillbis, Axe, V/Rad Studios, boris the blade
duncan
Post by duncan »
OUT FRONT
Turbotuber ST-200 > Klon KTR > Maxon OD808 > Diamond Boost EQ > Dixon Volume Pedal
LOOP
Diamond Memory Lane 2 > EQD Avalanche Run v2 > Walrus Fathom > Walrus Slö > Strymon El Capistan
Powered by a Cioks Cioklate
I used to play guitar.
greatmutah
Site Moderator
We got the Dunlop Crybaby -> PolyTune -> MXR Phase 90 -> Fulltone Deja Vibe -> SD-1 -> PLX Spirytus -> EQD Hizumitas -> Boss BF-2 -> EHX Small Clone -> EQD Afterneath -> Strymon El Capistan -> Boss NS-2 -> Radial Bigshot AB. Cioks DC-7 Power Supply.
The nice thing about this setup is it’s easy for me to separate the Afterneath and El Cap to put in the loop of an amp. This setup is how I run it to my Fender Rig. Perfect for cleans, modulations, Dream pop, muff affected distortions and pretending to play lead in Tears for Fears. The Hizumitas is my all out gain/lead tone. The Spirytus alternates as a heavy rhythm tone and lead if needed. They both sound awesome boosted.
One thing not on there is my SUF Astoria. It gets swapped in for the Spirytus to have two different muff flavors if I want that. The Hizumitas is based off a clone of a Triangle. The Astoria is a clone of a specific Ram’s Head. Both sound like Muffs but the differences are really cool. The Hizumitas is more scooped and smooth. The he Astoria has more grit in the mids.
Stratsouldier
Post by Stratsouldier »
Signal path is -> gig rig switcher -> Analogman Sun Lion -> Prescription Electronics C.O.B. -> Shin-Ei Vibe 2 -> Vemuram Jan-Ray -> Fulltone Hi-Mu -> Catalinbread Belle Epoch -> TC Flashback -> Strymon Flint -> out of the switcher and into the Poly Tune to the amp.
Go make me a drinky poo
greatmutah
Site Moderator
Time to vote.
