Small Footprint Mic Stands For Recording Guitar
DarthTangYang
Post by DarthTangYang »
I'm looking to mic up my speaker cab using the Fredman Technique (two SM57's, one straight into the cone at a 90° angle, the second in a 55° angle) and I've bought a Fredman Clip to help keep the mics in this configuration.
However, I was first thinking of getting a mountable stand in order to save space and to minimize any risk of knocking the mics out of position, i.e. something like the Audix Cab Grabber. But then someone pointed out that these are just gimmicks that should be avoided due to the fact that they will pick up vibrations from the cab, which when I came to think of it does make a lot of sense.
So I guess I'm back to finding a fairly regular floor based mic stand and perhaps someone have some suggestions for one that can sit really close and not protrude too far out from the cab? Perhaps even one that can sit behind or next to the cab and go over and/or around so to speak?
Also, the Fredman Clip doesn't come with a "swivel" attachment so it screws directly onto the stand/boom so perhaps I need some kind of swivel attachment as well in order to get it into the correct position, so any suggestions on that front are also very much welcome.
The Fredman Clip can be seen here:
https://fredmandigital.com/products/fredman-clip
GUITARS
• Epiphone Les Paul Studio - Ebony (2001, Korea) heavily modified.
• Epiphone Les Paul Standard - Iced Tea Burst (2022, China) stock gear.
AMPLIFIERS:
STEREO WET
• Two Hughes & Kettner Vortex Black Series, 100W heads.
• Two Hughes & Kettner 4X12 cabs with Celestion Rockdriver Jr. speakers.
MONO DRY
• Orange TH30 head.
• Harley Benton 2X12 cab with Celestion Vintage 30 speakers.
• Victory V4 "The Kraken" preamp pedal.
PEDALS
• Dunlop - CryBaby GCB95
• Electro Harmonix - Green Russian Big Muff Fuzz
• TC Electronic - Vortex Flanger
• Boss - DD-500
• Boss - RV-500
• Boss - EQ-200
• MXR - Talkbox
OTHER GEAR
• Wharfedale Pro 600 (PA-system for the Talkbox)
• Wharfedale Pro Speakers
Re: Small Footprint Mic Stands For Recording Guitar
I have this mic stand because I also wanted a small footprint.
However, I recommend the above tripod stand because, a heavy mic (or two SM57's) will tip this one over unless the boom is set up vertically.
https://www.sweetwater.com/store/detail ... tand-black
I use the little short tripod stands myself. Scored two of them cheap as shit years ago
ibenhad
Post by ibenhad »
These work great may just need a small sandbag or something to weight them down.
https://www.sweetwater.com/store/detail/MicStdDesk--on-stage-stands-ds7200b-adjustable-height-desktop-stand
Great transactions - Davidian, twisty, Dooredge, Mike LX-R, drkorey, Thurston, colejustesen, Mortatone, thesockmonster
Matt L "I've been losing gigs left and right ever since someone told people my pickups were made in Korea. Wasn't a problem before, in fact, they thought I sounded great!"
maggotspawn
Post by maggotspawn »
ibenhad wrote:These work great may just need a small sandbag or something to weight them down.
These are what I use. They work great.
